CallbackURL in pure HTML and JS usage of onlyOffice
Document Server releases and description of the update.
Postby Enelvin » Tue Mar 13, 2018 11:17 am
I want to use onlyOffice inside of a pure HTML and Javascript file. (All of their official examples are based on dynamic web pages like PHP, Node.JS and so on)
SO I installed the integration server of Onlyoffice and made the following html file based on the information placed here:
<html>
<head>
</head>
<body>
<div id="placeholder"></div>
<script type="text/javascript" src="http://localhost/web-apps/apps/api/documents/api.js"></script>
<script>
var config = {
    "document": {
        "fileType": "docx",
        "key": "Khirz6zTPdfd7",
        "permissions": {
            "comment": true,
            "download": true,
            "edit": true,
            "print": true,
            "review": true
        "url": "http://localhost:9500/martin/new.docx"
    "documentType": "text",
    "editorConfig": {
        "callbackUrl": "http://example.com/url-to-callback.ashx"
var docEditor = new DocsAPI.DocEditor("placeholder", config);
</script>
</body>
</html>
This code show the editor correctly and load the file. The only problem is callbackUrl which is not well explained in the API.
Now the questions are:
What is the correct callback url? Is this file exist somewhere in the installed integration server?
I guess I have to develope the url-to-callback.ashx file. In case yes then what do I have to write for this file? (Please note I can just use JS and not PHP or other dynamic web languages)
Enelvin
Re: CallbackURL in pure HTML and JS usage of onlyOffice
Postby Maxim » Fri Mar 16, 2018 12:27 pm
Hello Enelvin!
You cannot save the documents using JS and html only. If you delete callbackUrl you will be able just to open a doc. But for saving you need request handler.
Postby Enelvin » Mon Mar 26, 2018 3:37 pm
Hello, Maxim!
Can you help me create this request handler?
I plan to experiment in Python!
I'm having a hard time with this.
But before we even continue I want to tell you that the file in Onlyoffice does not even open.
As you can see in the image, the editor opens but does not allow any editing.
Enelvin
Postby Maxim » Tue Apr 03, 2018 10:23 am
Hello Enelvin!
Unfortunately no. Why do you need Document Server? What for?
Return to Document Server
Users browsing this forum: No registered users and 0 guests
