Opening .odt files without conversion
Postby alexis.rosano » Fri Feb 02, 2018 11:50 am
Hi all!
My company only works with .odt files. I know that OnlyOffice could open that files, with a previous conversion to .docx.
My question is if exists any way to open that files without conversion.
Regards!
alexis.rosano
Re: Opening .odt files without conversion
Postby Maxim » Wed Feb 07, 2018 12:52 pm
Hello alexis.rosano!
There is no way.
Postby sebastien » Tue Mar 13, 2018 4:10 pm
My Current configuration:
Nextcloud v13.0.0
Only Office Document Server v5.0.7
OnlyOffice Nextcloud plugin v1.2.0
Here:
https://helpcenter.onlyoffice.com/ONLYO ... rmats.aspx
I understand that OnlyOffice supports ODT file format.
I see in this configuration file
appconfig.php
that Nextcloud plugin can handle ODT in the "public $formats" array:
replacing this
"conv" => true
by this
"def" => true, "edit" => true
So my question is: why ODT is not set editable by default in the appconfig.php config file ?
Should I consider this as not safe yet ? As a result, should I leave appconfig.php unset as it is now ?
sebastien
Postby Maxim » Wed Mar 14, 2018 8:18 am
Hello sebastien!
Because document server cannot edit *.odt files, *.odt files need to be converted first to xlsx.
Postby sebastien » Fri Apr 13, 2018 4:57 pm
Hello Maxim,
My question was based on this statement you can read on the Tech faq if Document Server:
Q: What formats of files I can edit?
A: You can edit documents, spreadsheets and presentations of the most popular formats: DOC, DOCX, ODT, RTF, TXT, XLS, XLSX, ODS, CSV, PPTX, PPT, ODP
sebastien
Postby Maxim » Thu Apr 19, 2018 1:13 pm
Can you provide a link please?
Postby sebastien » Thu Apr 19, 2018 2:53 pm
Sure.
This one shows file formats Document Server handles:
Supported Formats of Electronic Documents
https://helpcenter.onlyoffice.com/ONLYOFFICE-Editors/ONLYOFFICE-Document-Editor/HelpfulHints/SupportedFormats.aspx
This one is the one I've extracted the previous lines from:
General Questions FAQ
https://helpcenter.onlyoffice.com/faq/technology.aspx
sebastien
Postby Maxim » Thu Apr 26, 2018 1:26 pm
Hello sebastien!
Thank you for your info!
You can edit documents, spreadsheets and presentations of the most popular formats: DOC, DOCX, ODT, RTF, TXT, XLS, XLSX, ODS, CSV, PPTX, PPT, ODP. While uploading or opening the file for editing, it will be converted to the Office Open XML format. It's done to speed up the file processing and increase the interoperability.
Users browsing this forum: Maxim and 1 guest
