[Solved] Override headers (templates)
Postby alexis.rosano » Wed Jan 10, 2018 12:14 pm
I'm using the templates plugin. It works very good.
My question is if exists any way to insert only one template per click.
For example, when I click a template, and then other one, the second templates appear below the first one.
Screenshot from 2018-01-10 09-01-29.png (220 KiB) Viewed 1390 times
In the attachment, you can see two differents templates.
I want to the second template override the first one.
Is that possible?
Regards!
Last edited by alexis.rosano on Wed Feb 07, 2018 2:14 pm, edited 2 times in total.
alexis.rosano
Re: Override templates
Postby Maxim » Thu Feb 01, 2018 11:09 am
Hello alexis.rosano!
Please specify version of Document Server you use.
Postby alexis.rosano » Thu Feb 01, 2018 12:27 pm
Onlyoffice Document Server is 5.0.6
alexis.rosano
Postby alexis.rosano » Fri Feb 02, 2018 11:59 am
alexis.rosano
Re: [Solved] Override templates
Postby Maxim » Wed Feb 07, 2018 12:51 pm
Great! ;)
