convert on the network folder
Postby roumanille » Wed Dec 20, 2017 8:36 am
I use document server with nextcloud and the files are stored on a network folder (CIFS)
The rights on this network folder are related to the user account.
To open docx files no problems, but .doc file conversions do not work on these network folders, on local folders it works :!:
Is it possible to change the conversion process for it to work on network folders as well :?:
roumanille
Re: convert on the network folder
Postby Maxim » Thu Dec 21, 2017 7:26 am
Hello roumanille!
We tried to reproduce the issue but had no luck.
It needs to see the nextcloud logs.
Postby roumanille » Thu Dec 21, 2017 7:56 am
attached log nextcloud.
Thanks
netcloud.zip
(533 Bytes) Downloaded 28 times
roumanille
Postby Maxim » Thu Dec 21, 2017 10:13 am
Hello roumanille!
Try this solution
Postby roumanille » Thu Dec 21, 2017 2:35 pm
YES it works !!!
thank you very much.
roumanille
Postby Maxim » Fri Dec 22, 2017 12:54 pm
Hello roumanille!
Glad to hear it!
