[Solved] Plugins for Onlyoffice doesn't appears
Postby alexis.rosano » Tue Dec 19, 2017 1:27 pm
Hi all!
I'm following this article https://api.onlyoffice.com/plugin/installation (precisely step 1) to add the template plugin.
I've added the plugin folder to /var/www/onlyoffice/documentserver/sdkjs-plugins in my docker instance (attachment)
But, I can't see the plugin in the Onlyoffice installation (attachment).
I'm forgetting something? I've already logout, restart Apache, restart docker instance but without success. BTW: I've deleted a folder and it does not appear anymore.
Regards.
Screenshot from 2017-12-19 10-10-52.png (46.63 KiB) Viewed 2337 times
Last edited by alexis.rosano on Thu Dec 21, 2017 12:51 pm, edited 1 time in total.
alexis.rosano
Re: Plugins for Onlyoffice doesn't appears
Postby Maxim » Tue Dec 19, 2017 2:02 pm
Hello alexis.rosano!
1. What version of Document Server is running?
2. Where did you get plugins?
There is one moment - plugins must be the same version as Document Server.
Now there is Document Server - 5.0.6 it means that if you download plugins now your doc server should be 5.0.6
Postby alexis.rosano » Tue Dec 19, 2017 2:06 pm
1. Onlyoffice Document Server is 5.0.6
2. Plugins from: https://github.com/ONLYOFFICE/sdkjs-plugins, precisely: templates and helloworld
alexis.rosano
Postby alexis.rosano » Thu Dec 21, 2017 11:29 am
May be I have to change the config too?
I've executed the next steps:
1. Download the sdkjs-plugins folder from https://github.com/ONLYOFFICE/sdkjs-plu ... /templates.
2. Compare the files in docker-component:/var/www/onlyoffice/documentserver/sdkjs-plugins/ocr with sdkjs-plugins/ocr
3. Verified that config.json, index.html and ocr.js are equals in both places.
4. Deleted the folder docker-component:/var/www/onlyoffice/documentserver/sdkjs-plugins/ocr
5. Checked in Nextcloud + Onlyoffice that the ocr plugin doesn't appears anymore.
6. Copy sdkjs-plugins/ocr folder from the host to the docker instance with the command
docker cp ocr c563e3574d97:/var/www/onlyoffice/documentserver/sdkjs-plugins
7. Go to NextCloud -> Onlyoffice -> Plugins.
8. The plugin doesn't appears :cry: :cry: :cry:
alexis.rosano
Re: [Solved] Plugins for Onlyoffice doesn't appears
Postby alexis.rosano » Thu Dec 21, 2017 12:52 pm
It was a permission issue from the host.
Regards!
alexis.rosano
Postby Maxim » Thu Dec 21, 2017 12:59 pm
My result - OCR plugin
1. I took OCR plugin using branch "Master"
2. And installed on the Document Server 5.0.6.14
It works.
Postby alexis.rosano » Thu Dec 21, 2017 2:03 pm
Hello Maxim, thanks for your help.
Now I'm working with the template plugin.
My problem is that I can't see my updates. Example: I deleted the calendar template, but I still see it in the OnlyOffice plugins.
This is the template.js (I delete the line with the calendar and added two more templates developed by me):
Screenshot from 2017-12-21 10-59-06.png (78.1 KiB) Viewed 2308 times
Then I copy the folder to the document server sdkjs-plugins
But, In the onlyoffice I still seeing the template that I've erased before.
alexis.rosano
Postby Maxim » Mon Dec 25, 2017 7:59 am
Try to clean browser's cache
Postby alexis.rosano » Tue Dec 26, 2017 2:17 pm
I did it.
The firts time, clean the browser cache works. But then, I added another change but without success (cleaning caché too).
Very strange.
alexis.rosano
Postby alexis.rosano » Wed Dec 27, 2017 12:58 pm
I've already tried:
1- Opening only office in new browsers (without caché)
2- Cleaning cache manually and with bleachbit
3- Uninstalling the onlyoffice docker image.
Everything without success.
alexis.rosano
Next
