Document Server Files caching
Postby ExaconAT » Fri Dec 01, 2017 7:44 am
what should i set at this part of the config, to enable Cache file deletion after, 30 Minutes (when there is no on logged in, or was in this time)
Little bit tweaked but wont work
/etc/onlyoffice/documentserver/default.json:
"saveLock": 60,
"presence": 300,
"locks": 604800,
"changeindex": 86400,
"lockDoc": 30,
"message": 86400,
"lastsave": 604800,
"forcesave": 604800,
"saved": 3600,
"documentsCron": "1 * * * *",
"files": 3600,
"filesCron": "1 * * * *",
"filesremovedatonce": 100,
"sessionidle": "0",
"sessionabsolute": "0",
"sessionclosecommand": "2m",
"pemStdTTL": "1h",
"pemCheckPeriod": "10m"
BR
ExaconAT
Re: Document Server Files caching
Postby Maxim » Mon Dec 04, 2017 8:55 am
Hello ExaconAT!
"files": 3600,
do not change "documentsCron"
you should change "files": 1800 (in seconds 60secx30min=1800sec)
filesCron - time when the delete process will be applied (once in 10 min)
