Success from LAN but "ONLYOFFICE cannot be reached" from WAN
Postby jcconnell » Wed Nov 29, 2017 4:51 pm
I'm using OnlyOffice with Nextcloud. I can access and edit documents from within Nextcloud while on my LAN but I receive the error in the title while trying to do the same from outside the LAN.
OnlyOffice runs on VM1, Nextcloud on VM2 and Nginx as a reverse proxy runs on VM3. Requests for cloud.example.com are proxied to Nextcloud (VM2). In the Nextcloud Admin settings, I added the OnlyOffice LAN IP.
I followed these instructions to install OnlyOffice on Ubuntu 16.04: https://helpcenter.onlyoffice.com/serve ... ation.aspx
Any ideas what the problem is?
jcconnell
Re: Success from LAN but "ONLYOFFICE cannot be reached" from
Postby Maxim » Thu Nov 30, 2017 12:15 pm
Please look here to configure correctly
Postby jcconnell » Thu Nov 30, 2017 1:52 pm
Thank you! I've read that resource. Which part is relevant here?
jcconnell
Postby Maxim » Mon Dec 04, 2017 8:35 am
Hello jcconnell!
Use "Advanced server settings" in Nextcloud admin panel and put your local NC address in "Server address for internal requests from the Document Editing Service"
