Is the Document Server Free ?
Postby Gromak123 » Tue Nov 07, 2017 4:29 pm
HI Guy,
I have just completed this tutorial https://serenity-networks.com/how-to-in ... fast-easy/ for installing the Document Server and linking it to my nextcloud.
But i have a question, i have understood that te community server is under AGPL licence but what for the document server ? Did i have just install a Trial version ?
Thank's :) !
Gromak123
Re: Is the Document Server Free ?
Postby Maxim » Fri Nov 10, 2017 12:35 pm
Hello Gromak123!
You can use it free with some limitations (20 simultaneous connections) or you can buy a licence for not to face these limitations.
Postby alexis.rosano » Tue Feb 20, 2018 1:22 pm
Do you have a link for pricing?
The only limit in free version is 20 connections in one document?
Regards.
alexis.rosano
Postby Maxim » Thu Feb 22, 2018 8:40 am
Hello alexis.rosano!
You should contact to sales@onlyoffice.com
It doesn't matter, you can open 20 different docs. It means that Document Server will process 20 connections.
