Error while downloading the document file to be..
Postby alexis.rosano » Wed Nov 01, 2017 8:29 pm
Hi all!
I could install de OnlyOffice Docker image in: http://localhost:8080.
The thing is when I want to configure the address in the administration of NextCloud, I get an error message:
Log saids:
“CommandRequest on check error: Error occurred in the document service: Error while downloading the document file to be converted.”
Somebody knows what I am missing?
Regards!
alexis.rosano
Re: NextCloud: Error while downloading the document file to
Postby Maxim » Thu Nov 02, 2017 6:36 am
Hello alexis.rosano!
URL is wrong (http://localhost:8080)
It must be valid accessible URL where your Document Server is located
Do you have two separated servers?
See here
Postby alexis.rosano » Thu Nov 02, 2017 7:42 pm
If I access that URL I see the message of the Document Server running OK!
I have only one server, I have NextCloud running in my Apache server (http://localhost/nextcloud) and the Docker image with (http://localhost:8080)
Regards,
alexis.rosano
Postby Maxim » Fri Nov 10, 2017 8:42 am
You cannot run two servers on localhost.
If you need to run on one machine you need to use docker installation
Postby alexis.rosano » Wed Dec 13, 2017 4:29 pm
Hello @Maxim, I could resolve my problem.
I put the Docker image with Document Server in a Virtual Box image and my Next Cloud installation in a public address (accessible too from the Virtual Box image)
Thanks again for your help!
alexis.rosano
Postby Maxim » Fri Dec 15, 2017 8:11 am
In that case it should work.
