Problem with Onlyoffice on Nextcloud with server encrytion
Postby marcelc » Fri Sep 29, 2017 1:10 pm
I have the Problem that I couldn't open my Documents with onlyoffice over the nextcloud since I activated the server-side encryption.
I tried to solve the problem by myself but I couldn't find a soution.
At the nextcloud I could a enter a secret key for onlyoffice, I think this is neccary to open the encrypted files but I'dont know wich seceret key i should you.
Can anyboby help me?
marcelc
Re: Problem with Onlyoffice on Nextcloud with server encryti
Postby Maxim » Mon Oct 02, 2017 8:11 am
Hello marcelc!
...since I activated the server-side encryption.
How did you activate?
If you put your secret key (this key depends on you, you can put any word, numbers and so on) this key will be automatically set on the side of the Document Server.
Postby marcelc » Wed Oct 04, 2017 6:24 am
Where can I found the correct secret key?
I doesn‘t enter a secret key on anytime and I don‘t know which key I should enter for the onlyoffice app.
marcelc
Postby marcelc » Wed Oct 04, 2017 7:10 am
I put a custim secret key in the app field. But it doesn't work
marcelc
Postby marcelc » Wed Oct 04, 2017 1:45 pm
I set a custom key but it doesn't work.
I found this: https://api.onlyoffice.com/editors/signature but not sure where to set the key.
I tried some configutation but the problem is still there
marcelc
Postby Maxim » Mon Oct 09, 2017 6:37 am
Hello marcelc!
How did you activate the server-side encryption?
