OnlyOffice and ownCloud on the same server?
Postby weissb95 » Mon Sep 25, 2017 8:50 pm
I have installed Onlyoffice document server and it is running. To use ownCloud, i have to stop the nginx service and start the httpd service.
Then i could configure ownCloud to work on my server.
But i read in the integration tutorial that they need to be installed on different computers and this is a huge inconvenience. Is there any way i can have ownCloud work on nginx as well so both Onlyoffice and ownCloud can be on the same server and functioning/running at the same time?!
weissb95
Re: OnlyOffice and ownCloud on the same server?
Postby Maxim » Tue Sep 26, 2017 6:28 am
Hello weissb95!
You can run both servers on the same machine (on different ports) but you have to configure ngnix (proxying). But how can you do this It's up to you.
