Timezone issue with document comments
Postby sethbgm » Mon Jul 31, 2017 12:43 am
Hi there,
OnlyOffice seems to be working great with my NextCloud, but there is one issue that is pretty significant. I have some users that are in another timezone (three hours behind mine) and when we work on documents together in real-time and communicate through comments, they are out of order because it sees their comments as being posted at an earlier time than mine since I am three hours ahead.
Does anyone know how I can fix this? Thank you
sethbgm
Re: Timezone issue with document comments
Postby Maxim » Tue Aug 01, 2017 7:45 am
Hello sethbgm!
Please specify your Onlyoffice version and it would be great if you attach a screenshot of the issue.
Postby sethbgm » Tue Aug 01, 2017 3:55 pm
My OnlyOffice version is 4.3.6. Attached to this post is an example of what I mean. I added in red the order that each comment was posted, but as you see, they are out of order because I am in a later timezone than the other user. Let me know if you would like more information
sethbgm
Postby Maxim » Wed Aug 02, 2017 11:44 am
Hello sethbgm!
Honestly to say it's not a bug! We had to do comments that way because of compatibility with MS Word. But MS Word does not have Collaborative Document Editing unlike Onlyoffice. We have a solution of that issue but we will implement it later.
