"The file version has changed. The page will be reloaded"
Postby kommid » Thu Jun 08, 2017 2:08 pm
I have the docker version on debian jessie and since today, whenever I want to edit an excel file I get the error message: "The file version has changed. The page will be reloaded". When I click on OK the page reloads and I get the same message over and over. I tried to save the file and work on a copy, but after closing it and re-opening the file, I have the same problem again.
Also I'm not able to delete the file: After un-sharing it I can only copy or download it, leaving me with several unusable documents.
We are in the process of evaluating Onlyoffice but this behavior is not very promising. Does anyone have an idea, what the problem might be here and how I can solve it?
kommid
Re: "The file version has changed. The page will be reloaded
Postby Maxim » Tue Jun 13, 2017 11:10 am
Hello kommid!
Please specify what instruction did you follow to install Onlyoffice?
