Docker vs direct Installation
Postby Taste » Wed May 03, 2017 7:43 am
and thanks for making that. I actually tested Nextcloud with ONLYOFFICE and use it in the Docker Container. As far as i read, i can use OO on a real Installation too. So my question is, what are the Pros and Con of both of them. It whould be nice to get some facts. thx
Taste
Re: Docker vs direct Installation
Postby Maxim » Thu May 04, 2017 7:14 am
Hello Taste!
Docker+: separate container with OO and OS, no need to install prerequisites
RPM+: clean installation, some says that it's much faster but i think it depends on configuration.
Postby Taste » Thu May 04, 2017 8:00 am
Hi Maxim,
ok understand. As far as i understand docker, its only a container which uses the ressources of the host, right? its not like an kvm vm, where you have to configure the ressources and set them up, right? Is it possible to reconfigure / fine tune the docker container?
Taste
Postby Maxim » Thu May 04, 2017 8:23 am
Why? What for? The Docker container has been already configured.
See here if you need.
Postby Taste » Thu May 04, 2017 8:51 am
was just an idea to optimize some facts. Ok i have to read more about docker :)
Taste
Users browsing this forum: Google [Bot] and 3 guests
