Hi to everybody!
Just was try the first time to install the Docker Version and something went wrong!
I use a Debian 8 (Jessie) (Minimal-)Server and installed OnlyOffice from Command Line. After done that, I was try to start OO from Browser and it didn't, neither with the local IP of the server (192.168.1.18) nor Localhost etc., etc.!
So I checked how to remove Docker from Server ( https://helpcenter.onlyoffice.com/serve ... emove.aspx) and that didn't works! Docker isn't to be found on my Serv er!
Could someone please explain How To remove the whole Package from my Server, and after that, How To Install on Debian 8.7.1 Jessie Minimal Server? I could simply just re-install Debian again if needed!
Thanks for any answer and/or advice.
