Incredibly slow set up?
Postby catmanjan » Mon Apr 24, 2017 6:44 am
Running docker on Windows 10, got it all running and I'm at Startup.aspx
It's been going for about half an hour and it's only at 4%, docker stats show the containers ranging from 30-100% usage.
Is this normal? How long does it take to set up the first time?
catmanjan
Re: Incredibly slow set up?
Postby Maxim » Mon Apr 24, 2017 10:59 am
Hello catmanjan!
It's not normal. Setting up is about 15 min.
Postby catmanjan » Tue Apr 25, 2017 1:15 am
Well how should i determine what the issue is?
Aren't the containers the same for everyone, is it a bad release?
catmanjan
Postby Maxim » Tue Apr 25, 2017 7:06 am
Hello catmanjan!
Honostly to say i have no idea!
What is the Onlyoffice docker installation do you try to install? What instruction did you use to install Onlyoffice for Docker?
Postby catmanjan » Tue Apr 25, 2017 9:30 pm
That doesn't instill much confidence in support..
I followed this http://helpcenter.onlyoffice.com/server ... ation.aspx
Cant run batch scripts on windows so I ran each docker command as specified
catmanjan
