How to install document server in unRaid?
Postby relink » Sun Apr 23, 2017 5:19 pm
I am new to unraid, docker, and onlyoffice, all at the same time! lol
I have been trying for 2 days to get onlyoffice to run in docker under unraid, and have had very little success. Here is what my goal is.
-I would like to use onlyoffice docker, in unraid. I just want to be able to store, create, and edit, word, excel, and ppt docs (the basic stuff), collaboration would be nice, but i don't need any other features. Mostly going to be use used by 2 users, maybe up-to 5 later on.
-I would like to be able to access through https if possible
-I would definitely like to be able to use the mobile app (especially iOS), i don't know if there is anything special I need to do to make this work.
-I need to be able to run only office on different port numbers, I really don't want it on ports 80 and 443.
-Lastly I would prefer to be able to store all the documents on a share outside of docker if possible, or at least make the only office data directory accessible over my network as a smb share. (I am terrified of loosing all my docs if something goes wrong down the road)
I dont know if this is a tall order or not, but hopefully someone can help me out. The way people talk about installing onlyoffice in docker it doesn't seem like its hard at all. But its a totally new tech to me and it seems like the more tutorials i look up the more confused I get.
relink
Re: How to install document server in unRaid?
Postby Maxim » Mon Apr 24, 2017 7:32 am
Hello relink!
    We didn't test Onlyoffice on UnRaid
    You should use Integration Edition, Community Edition or Enterprise Edition
    Onlyoffice supports HTTPS
    There is Onlyoffice app in AppStore
See here
    You can use custom ports using Document Server ver 4.3.0 or higher
In your case i suppose it would be great to use Integration Edition.
Postby relink » Sat Apr 29, 2017 8:09 pm
I have managed to get Onlyoffice Community server and Document server both successfully installed in unraid Docker. However I am now hitting a roadblock trying to connect the two together. any time I try to connect the communityserver to the document server I get an error "Api url: Service is not defined"
relink
Postby relink » Sun Apr 30, 2017 5:32 am
I was never able to get only office to run in unRAID. I did however get it to run fine in a Ubuntu VM that hosted on unraid...so I guess thats close...
relink
Postby Maxim » Tue May 02, 2017 6:36 am
Hello relink!
Did you run OO successfully in unraid Docker ?
Postby tbrasser » Tue May 23, 2017 11:40 pm
I'm getting the following errors:
ng message broker rabbitmq-server  * FAILED - check /var/log/rabbitmq/startup_\{log, _err\}
31mfail]
redis-server: redis-server.
for connection to the localhost host on port 5672
I currently run Nextcloud 12.0.0 on unRAID 6.3.4 and trying to switch to OnlyOffice DocumentServer from Collabora/CODE.
tbrasser
Postby Maxim » Wed May 24, 2017 3:10 pm
Hello tbrasser!
Specify please how did you try to switch to OnlyOffice DocumentServer from Collabora/CODE.
Postby tbrasser » Fri May 26, 2017 10:03 am
Basically switching in this case just means, disable Collabora, disable the app in Nextcloud. Then running the (simplest) DocumentServer run command.
However I can't get the OnlyOffice DocumentServer docker image to run without it giving me the errors I posted. (Seems like RabbitMQ and Redis aren't running properly)
tbrasser
Postby tbrasser » Fri May 26, 2017 10:09 am
(If this is a double post please delete it, I tried submitting one but it didn't show up)
I've read that you can run both Collabora and OnlyOffice at the same time without them interfering in Nextcloud. However I have tried all sane things (making sure my mapped volumes are empty, removing the collabora container, disabling the collabora app in Nextcloud) however I have trouble getting the DocumentServer container to run, it results in the errors I posted above.
I have 6+ gb of ram free, +40gb of hard-drive space, and a (old) quadcore i3 (2ghz+), so that shouldn't be the cause of Redis and RabbitMQ failing right?
tbrasser
Postby Maxim » Fri May 26, 2017 2:04 pm
Hello tbrasser!
I think that you should try to install Document Server on fresh ubuntu installation.
Next
Users browsing this forum: Baidu [Spider] and 2 guests
