Server performance more frequently 404 errors
Postby ben3 » Tue Mar 07, 2017 2:54 am
I'm sorry to ask some question for docker of community server.
I've install CommunityServer with DocumentServer and MailServer on CentOS 7 use Docker.
But when I access web with localhost, the page show 404 error.
then I refresh the page times, and it's show more frequently to display 404 error
How can I fix it?
CPU:I5 6400
RAM:16G
DISK:250G SSD
OS:CentOS7
Docker:
Client:
Version: 17.03.0-ce
API version: 1.26
Go version: go1.7.5
Git commit: 3a232c8
Built: Tue Feb 28 08:10:07 2017
OS/Arch: linux/amd64
Server:
Version: 17.03.0-ce
API version: 1.26 (minimum version 1.12)
Go version: go1.7.5
Git commit: 3a232c8
Experimental: false
ben3
Re: Server performance more frequently 404 errors
Postby Maxim » Tue Mar 07, 2017 6:46 am
Hello ben3!
Have you got access to 192.168.1.5 earlier or it occurred after the fresh installation?
Postby ben3 » Tue Mar 07, 2017 7:32 am
Dear Maxim.
I have aleardy reinstall the docker and all images of onlyoffice community server yet. But the problem is already exist.
I monitor the usage of CPU and Memory, it's ok too
I don't know how it hanppend.
ben3
Postby ben3 » Wed Mar 08, 2017 12:53 am
Maxim wrote:Hello ben3!
No,It's a brand new system I've reinstalled
All in OS is new include Docker
ben3
Postby Maxim » Thu Mar 09, 2017 7:04 am
Hello ben3!
1 Do you still use CentOS? Specify your new OS installation please if it's not CentOS.
2 Check firewall. Use following commands
systemctl status firewalld
systemctl disable firewalld
systemctl stop firewalld
or
service iptables status
service iptables stop
service iptables start
If it's on try to disable and check OO.
3 Use command docker ps to check containers and ports. 80 and 443 must be opened.
4 Also try to install Ubuntu 16/04 for OO
