Fresh install Mixed language
Postby cedric.reymond » Mon Feb 06, 2017 9:32 am
I am testing only office.
I have done a fresh install using the guide with docker.
The install went fine, but the only office have some section in another language (greek ok russsian).
I have tried to switch the site language to other English US or UK , but these sections does not change...
Any idea?
Cedric
cedric.reymond
Re: Fresh install Mixed language
Postby Maxim » Mon Feb 06, 2017 3:02 pm
Hello cedric.reymond!
It's russian language.
So try to change Language and Time Zone Settings in Settings->Common->Customization
Go to Administrator profile and change Language:
Also try
sudo rm -R /app/onlyoffice/ControlPanel/data/bundle/
and
service monoserve restart
service monoserve2 restart
service redis-server restart
redis-cli flushall
Postby cedric.reymond » Mon Feb 06, 2017 3:45 pm
I already tried to change the language and time zone, no success...
The first command give the following message:
can not remove ... no such file or directory.
It is really Strange to have mixed languages..
cedric.reymond
Postby cedric.reymond » Mon Feb 06, 2017 3:48 pm
Thanks for your reply.
I already tried to change the language without any success..
Your first command give the following result:
cannot remove, no such file or directory....
cedric.reymond
Postby Maxim » Tue Feb 07, 2017 10:35 am
i'm very surprised to see such bug honostly to say )))...so try to reinsatll OO, but before (if you use Docker version) delete all containers and script which you used to install OnlyOffice. I advice you to use Enterprise or Community Edition for Docker
Postby cedric.reymond » Thu Feb 09, 2017 9:20 am
Hello Maxim,
I have done a new install of Ubuntu and OO.
Now everything look correct.
We just done some testing but the site is extremely slow...
Upload/Dl is fine, but editing a simple excel document is very slow then we have an error saying the document could not be saved....
cedric.reymond
Postby cedric.reymond » Thu Feb 09, 2017 9:25 am
I can open the sample document to edit.
I can add a word in a row, then go back to document
All this is fine. but if I reopen the edited document, then it take more than a minute to popup the error and display the document...
Very Strange.
OO Community is running on Ubuntu 16.04 on a Hyper-V server.
cedric.reymond
Postby cedric.reymond » Thu Feb 09, 2017 9:42 am
This the content of Chrome console when I try to edit a document:
Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
(anonymous) @ /2017-02-03-11-13/web-apps/apps/spreadsheeteditor/main/app.js:8
http://***/2017-02-03-11-13/web-apps/apps/spreadsheeteditor/main/app.js Failed to load resource: the server responded with a status of 404 (Not Found)
_get @ /2017-02-03-11-13/web-apps/apps/spreadsheeteditor/main/app.js:8
app.js:8 GET http://***/2017-02-03-11-13/web-apps/apps/spreadsheeteditor/main/resources/help/fr/Contents.json 404 (Not Found)
send @ app.js:8
ajax @ app.js:8
o.ajax @ app.js:8
o.sync @ app.js:8
sync @ app.js:8
fetch @ app.js:8
setLangConfig @ app.js:8
applyMode @ app.js:8
setMode @ app.js:8
setMode @ app.js:8
onDocumentReady @ app.js:8
onLongActionEnd @ app.js:8
f.trigger @ sdk-all-min.js:369
H.Wq @ sdk-all-min.js:417
H.sS @ sdk-all-min.js:398
H.Yrb @ sdk-all-min.js:444
updateAfterApplyChanges @ sdk-all-min.js:439
(anonymous) @ sdk-all-min.js:375
(anonymous) @ sdk-all.js:7305
H.gsc @ sdk-all-min.js:436
e0a @ sdk-all.js:5720
S2c @ sdk-all.js:5720
H.Q7 @ sdk-all-min.js:437
A.TWc @ sdk-all.js:7303
H.crd @ sdk-all-min.js:444
applyChanges @ sdk-all-min.js:439
H.Ysa @ sdk-all-min.js:375
H.Kod @ sdk-all-min.js:438
H.Poc @ sdk-all-min.js:447
Wnc @ sdk-all.js:5721
app.js:8 GET http://***/2017-02-03-11-13/web-apps/apps/spreadsheeteditor/main/resources/formula-lang/fr_desc.json 404 (Not Found)
cedric.reymond
Postby Maxim » Thu Feb 09, 2017 12:27 pm
I suppose that there is smth. wrong with connection between docker containers according to 404 error....
So check out next:
1 firewall should be disabled
2 80 and 443 ports must be opened and not busy
3 did you change Settings->Document Service?
4 how to find out container's ID use command
docker ps
5 enter the Community Server Container
docker attach [container's ID]
(it's enough to enter the first 3 symbols of ID)
6 run command from Community Server container
wget http:yourIPaddress(domain)/OfficeWeb/apps/api/documents/api.js
you must see Saving to:'api.js' if it is so it means your Document Server is online for Community Server.
Postby cedric.reymond » Thu Feb 09, 2017 12:44 pm
Hello MAxim,
point 1 & 2 are fine.
I changed point 3 then rebooted the linux as it was still not working and after reboot all configuration is gone!
I was asked to setup the initial account!!!
Now I try to changing point 3 again, and I have the error saying:
Api url: Service is not defined!!
running step 4-6 I receive a 404 error...
using ip or name
Any idea??
It looks like it is very complex to have this running!!
cedric.reymond
Next
