Instructions to upgrade to latest images for community serv
Postby minhuy » Mon Dec 19, 2016 8:01 pm
I kept finding but could not find any clear and full instruction to upgrade docker image of community and document server to the latest version. I see usually couple weeks or months onlyoffice will release new image to docker image hub. I want to keep my server up to date for security purposes. Could I have a clear and full detail step by step to upgrade docker images of community and document servers to the latest version? Thank you so much in advance.
minhuy
Re: Instructions to upgrade to latest images for community s
Postby Maxim » Tue Dec 20, 2016 7:10 am
1. If you're using Enterprise Edition follow this instruction, also you can use search page in our helpcenter.
2. How to upgrade your Docker Community Server to the latest version see here
3. If you have mapped folders (to save your data) and used Community Edition you can just remove old containers and install again using provided script
If you have questions about Update please specify what installation of OnlyOffice you're using. It's important to understand how to help you.
Users browsing this forum: No registered users and 6 guests
