Server Community Edition & Server Enterprise Edition: compar
Postby troy.vo » Thu Nov 24, 2016 4:40 am
Hi All,
I'm new with onlyoffice. I have a questions about the License on the http://helpcenter.onlyoffice.com/tipstr ... erver.aspx I saw
"Server Community Edition" version is not support function "Online Editors" . But after install onlyoffice (by Docker) on Ubuntu 16.04 and I can use function online editor on web.
More question, If this version is total free for editor online and it will work well with how many users?
Thanks.
Server Community Edition & Server Enterprise Edition comparison.png (52.3 KiB) Viewed 1130 times
troy.vo
Re: Server Community Edition & Server Enterprise Edition: co
Postby Maxim » Thu Nov 24, 2016 7:19 am
OnlyOffice Community Edition has a number of limitations such as: one CPU core and 20 simultaneous connections to Document server. It means that Document Sever may work with 20 simultaneous documents (connections) opened by you or someone else. The 21st connection will be able in view mode only!
So if you need to work with documents online in small groups Community Edition could be a good solution for you!
