Document Server only returns GET error
Postby joshuajnoble » Mon Oct 31, 2016 6:48 pm
I have the OO Document Server installed and it seems to start up fine (according to the Docker logs anyways) so I see:
root@8bd33c5d8e13:/#
 * Starting PostgreSQL 9.3 database server                               [ OK ]
Starting redis-server: redis-server.
 * Starting message broker rabbitmq-server                               [ OK ]
Starting supervisor: supervisord.
onlyoffice-documentserver:docservice: stopped
onlyoffice-documentserver:docservice: started
onlyoffice-documentserver:converter: stopped
onlyoffice-documentserver:converter: started
But when I go to the port on which I have the server installed I just get:
Cannot GET /
Is this a sign of some misconfiguration on my end?
joshuajnoble
Re: Document Server only returns GET error
Postby Maxim » Tue Nov 01, 2016 6:19 am
It means that OO Document Server works fine and you can proceed integration process of server to your host.
