Documents editing error
Postby viktor.szanto » Tue Oct 18, 2016 10:37 am
Hi!
I have installed an ONLYOFFICE community version. I used the install script (opensource-install.sh -ims false)
http and https is enabled (ssl crt and key installed correctly)
My problem is:
If I connect to LAN IP the document editing is working correctly. Co-editing and save, close etc are ok!
If I connect to external (WAN) IP or FQDN the document editing is wrong. The document saves not done and I can't reopening the document.
The infrastructure:
WAN IP is on Juniper SSG-550. The VIP address ports (443, 80) connected to the local host IP. The docker based ONLYOFFICE running on this host.
I tried to:
In Settings >> Common >> Customization >> DNS Settings set up my own FQDN
In Settings >> Integration >> Document Service: all field editing http(s)://my.fqdn/... If I click the save button the server answer is: time out.
ONLYOFFICE detail:
onlyoffice/communityserver:8.9.1.191
onlyoffice/documentserver:4.1.5.1
viktor.szanto
Re: Documents editing error
Postby Maxim » Tue Oct 18, 2016 12:51 pm
Please send us an email (to support@onlyoffice.com) with domain name of onlyoffice portal, login and password to log in ONLYOFFICE portal to verify the problem. And put into email link to your post in forum.
Postby viktor.szanto » Tue Oct 18, 2016 1:19 pm
Thanks for the quick response,
*** Problem solved ***
Not ONLYOFFICE settings were wrong. The Juniper settings were not correct.
I'm sorry!
Thanks,
Best Regards,
Viktor
viktor.szanto
