[DocumentServer] Conversion Failed
Postby Toumassa » Mon Oct 10, 2016 9:17 am
I successfully installed docker version of OnlyOffice/Document Server on my server running Centos 7.2 (kernel 3.10.0-327.36.1.el7.x86_64, Docker version 1.12.1) which meets the minimal hardware requirements.
The servers correctly responds on port 443 with certificates correctly installed. My problem is that when i'm trying to load/edit a document, after loading the application the error "Conversion Failed" appears.
The loaded file is a correct .docx file. You can find a screenshot of the error. Thanks for your help.
Best Regards,
Arthur
Error while loading a .docx file
Toumassa
Re: [DocumentServer] Conversion Failed
Postby Eugenie » Mon Oct 10, 2016 3:24 pm
Please send us .log files of document server from container
/var/log/onlyoffice/documentserver/docservice/out.log
Please send us the whole file to support@onlyoffice.com
Eugenie
