Api url: Service is not defined
Postby rizhee » Fri Sep 23, 2016 7:37 am
I have installed onlyoffice community server + doc + mail in centos 7 Docker
as the server is webserver with installed virtualmin, I need port 80 for web.
So I changed onlyoffice ports to:
onlyoffice-mail-server \
-p 26:25 -p 144:143 -p 588:587 \
onlyoffice-community-server \
-p 8080:80 -p 5223:5222 -p 444:443 \
but i cannot edit files online. I tried to change Document Service Location to domain.com:8080 but there is a problem with Api url: Service is not defined
Console shows that script is using default web port http://domain.com/2016-09-05-09-13/web- ... nts/api.js
How to solve this?
Changing this line -e DOCUMENT_SERVER_PORT_8080_TCP_ADDR=onlyoffice-document-server \ didn't help neither.
rizhee
Re: Api url: Service is not defined
Postby Alex » Tue Sep 27, 2016 3:16 pm
Hello
I regret to inform you that there is no way to use the current version on a custom port, switch to 80, it will resolve the issue
Best regards
Alex
