Download Failed error when opening document
Postby firlevapz » Fri Jul 15, 2016 8:33 am
I installed the current mailserver, document-server and community-server with HTTPS via docker installation script.
From time to time i get this error when I upload a new document or when I share an existing:
"Download Failed. Press OK to return to ..."
Then when i restart the document-server docker container, it usually works again...
I figured out that there is an exception thrown by nodejs an logged in /app/onlyoffice/DocumentServer/logs/documentserver/converter/out.log
[2016-07-15 08:03:56.280] [ERROR] nodeJS - error downloadFile:url=https://docs.example.com/products/files/httphandlers/filehandler.ashx?action=stream&fileid=37&version=5&stream_auth=206265832982.IJEPMN945PZVF9OO5MPLLIPP2HNDRDEQ2MAUV8KEA;attempt=2;(id=7DAuoz7BW5OqJXh1B4Q_)
Error: Parse Error
    at Error (native)
    at TLSSocket.socketOnData (_http_client.js:320:20)
    at emitOne (events.js:77:13)
    at TLSSocket.emit (events.js:169:7)
    at readableAddChunk (_stream_readable.js:153:18)
    at TLSSocket.Readable.push (_stream_readable.js:111:10)
    at TLSWrap.onread (net.js:531:20)
We would also pay around $50 if someone could help us fixing this issue and have onlyoffice running stable...
Thanks!!
firlevapz
Re: Download Failed error when opening document
Postby Alex » Wed Aug 17, 2016 9:01 am
Hello
Please send a request to server@onlyoffice.com
Provide a detailed description of the issue
Alex
Postby nommaz » Mon Dec 19, 2016 8:17 pm
I have the same issue.. If it was resolved please post details
nommaz
Postby Maxim » Tue Dec 20, 2016 6:55 am
nommaz wrote:I have the same issue.. If it was resolved please post details
Please specify server's OS, what installation you're using (docker or pgkes). What error do you see? Please describe the issue in details.
Postby nommaz » Sat Dec 31, 2016 12:45 pm
my issue was solved. it was due to using custom https port on document server and some routing issues
nommaz
Postby Maxim » Tue Jan 03, 2017 8:14 am
I'm glad you've solved the problem! We always advice users to use standart ports (80, 443).
