Sphinx Settings - Full Text Search deamon not running
Re: Sphinx Settings - Full Text Search deamon not running
Postby penzoiders » Tue Dec 15, 2015 6:45 am
Thank you Dean,
Hope that my report helped somehow..
so, can I just start again from scratch and wait the next release to run the new containers?
hopefully my data directories will be the same and Full Text Search should just be working, right?
Let me know If you want me to test a beta build, I'm keen to help testing.
thanks again.
have a nice day.
penzoiders
Postby Dean » Tue Dec 15, 2015 11:00 am
Yes, Your message was helpful. It will be just the same except of some bugfixes.
I think no beta-testing is needed, as it's a minor release. But thank you for your suggestion anyway.
Postby jsdckr » Thu Feb 09, 2017 12:48 pm
Greetings
A quick post to ask if this issue was successfully resolved? Fresh install here on Debian - tried both with Docker and direct install - and just the same problem.
I'd really appreciate any help or suggestions....
With grateful thanks
Jamie
jsdckr
Postby Maxim » Tue Feb 28, 2017 8:05 am
Hello jsdckr (Jamie)!
Describe your issue in details please!
Previous
