Sphinx Settings - Full Text Search deamon not running
Postby penzoiders » Tue Dec 01, 2015 11:21 pm
I'm running community server linked to a document server with docker, version 8.6.0.24
I'm using a clean ubuntu server 14.04 LTS and docker-engine from docker repo
I followed the istructions on how to link and run document and community server on https here http://helpcenter.onlyoffice.com/it/ser ... index.aspx
these are the docker commands I've set to start the containers
docker run -i -t -d --name onlyoffice-document-server --restart=always onlyoffice/documentserver
docker run -i -t -d -p 80:80 -p 443:443 -p 5222:5222 --name onlyoffice-community-server --restart=always --link onlyoffice-document-server:document_server -v /opt/onlyoffice/Logs:/var/log/onlyoffice -v /opt/onlyoffice/Data:/var/www/onlyoffice/Data  -v /opt/onlyoffice/MySQL:/var/lib/mysql  onlyoffice/communityserver
I've fixed an external folder permission issue by entering the container and giving these commands (worked fine)
docker attach onlyoffice-community-server
chown -R --reference /var/www/onlyoffice/Services /var/www/onlyoffice/Data
chmod -R --reference /var/www/onlyoffice/Services /var/www/onlyoffice/Data
everything works except for the full text search.
I've entered the container and the onlyofficeIndex service is up and running
:/# service onlyofficeIndex status
onlyofficeIndex is running (pid 644)
sphinx is installed into the container and version is ok
:/# dpkg -s sphinxsearch
Package: sphinxsearch
Status: install ok installed
Priority: optional
Section: misc
Installed-Size: 21557
Maintainer: Sphinx package builds <builds@sphinxsearch.com>
Architecture: amd64
Version: 2.2.9-release-0ubuntu12~trusty
everything is to default in the settings page for sphinx settings: "localhost" and "9306"
as I test I get an error that the service is not running (am I supposed to set some other port, container ip, open some firewall port or configure something into the container in order to make it work?)
thanks for the advice and for the great piece of software, really enjoying it so far.
Lorenzo
full text search deamon not running
penzoiders
Re: Sphinx Settings - Full Text Search deamon not running
Postby Dean » Wed Dec 02, 2015 8:44 am
Could you please check the following folder on host to contain data:
/opt/onlyoffice/Data/Index
If there is no data, please perform:
sudo chmod 777 /opt -R
Postby penzoiders » Wed Dec 02, 2015 9:25 am
Thanks Dean for the quick response,
there's data in there
from outside the container
root@docs:~# ls -l /opt/onlyoffice/Data/Index/
total 0
drwxr-xr-x  8 landscape messagebus  79 Dec  1 14:51 community
drwxr-xr-x 10 landscape messagebus 103 Dec  1 14:51 crm
drwxr-xr-x  4 landscape messagebus  30 Dec  1 14:51 files
drwxr-xr-x  4 landscape messagebus  32 Dec  1 14:51 mail
drwxr-xr-x  7 landscape messagebus  80 Dec  1 14:51 projects
from inside the container
root@docs:~# docker attach onlyoffice-community-server
root@469b131337f2:/# ls -l /var/www/onlyoffice/Data/Index/
total 0
drwxr-xr-x  8 onlyoffice onlyoffice  79 Dec  1 14:51 community
drwxr-xr-x 10 onlyoffice onlyoffice 103 Dec  1 14:51 crm
drwxr-xr-x  4 onlyoffice onlyoffice  30 Dec  1 14:51 files
drwxr-xr-x  4 onlyoffice onlyoffice  32 Dec  1 14:51 mail
drwxr-xr-x  7 onlyoffice onlyoffice  80 Dec  1 14:51 projects
and seems to be effectively written
root@469b131337f2:/# ls -l /var/www/onlyoffice/Data/Index/files/file/
total 56
-rw-r--r-- 1 onlyoffice onlyoffice  84 Dec  2 09:15 delta.new.spa
-rw-r--r-- 1 onlyoffice onlyoffice  79 Dec  2 09:15 delta.new.spd
-rw-r--r-- 1 onlyoffice onlyoffice   1 Dec  2 09:15 delta.new.spe
-rw-r--r-- 1 onlyoffice onlyoffice 354 Dec  2 09:15 delta.new.sph
-rw-r--r-- 1 onlyoffice onlyoffice 665 Dec  2 09:15 delta.new.spi
-rw-r--r-- 1 onlyoffice onlyoffice   0 Dec  2 09:15 delta.new.spk
-rw-r--r-- 1 onlyoffice onlyoffice   0 Dec  2 09:15 delta.new.spm
-rw-r--r-- 1 onlyoffice onlyoffice   1 Dec  2 09:15 delta.new.spp
-rw-r--r-- 1 onlyoffice onlyoffice   1 Dec  2 09:15 delta.new.sps
-rw-r--r-- 1 onlyoffice onlyoffice   0 Dec  1 14:51 main.new.spa
-rw-r--r-- 1 onlyoffice onlyoffice   1 Dec  1 14:51 main.new.spd
-rw-r--r-- 1 onlyoffice onlyoffice   1 Dec  1 14:51 main.new.spe
-rw-r--r-- 1 onlyoffice onlyoffice 354 Dec  1 14:51 main.new.sph
-rw-r--r-- 1 onlyoffice onlyoffice   1 Dec  1 14:51 main.new.spi
-rw-r--r-- 1 onlyoffice onlyoffice   0 Dec  1 14:51 main.new.spk
-rw-r--r-- 1 onlyoffice onlyoffice   0 Dec  1 14:51 main.new.spm
-rw-r--r-- 1 onlyoffice onlyoffice   1 Dec  1 14:51 main.new.spp
-rw-r--r-- 1 onlyoffice onlyoffice   1 Dec  1 14:51 main.new.sps
-rw-r--r-- 1 onlyoffice onlyoffice   1 Dec  1 14:51 main.tmp.tmps
any clues?
should I really use chmod 777 -R on all opt?
or is there anything else I should seek for?
penzoiders
Postby penzoiders » Wed Dec 02, 2015 1:17 pm
I had a test and on a brand new and empty /opt/onlyoffice folder I tried to give 777
I've restarted the container and it worked. (did not work by chmodding 777 a populated /opt folder.. worked only by starting from scratch)
anyway I'm not too keen in putting in production my data folder with 777 permissions.
can someone share the correct chmod for all the data folders?
I'll try now another run by giving the uid and gid of user and group onlyoffice to the external /opt folder to see if default permissions work whitout chmodding it badly.
any advice is welcome.
penzoiders
Postby Dean » Wed Dec 02, 2015 1:57 pm
It can be enough to be 755, but let me ask you, what was the purpose of performing that commands:
The access rights inside the container should be:
drwxr-xr-x  7 onlyoffice onlyoffice 4096 Dec  2 10:57 Services
drwxrwxrwx  7 root       root       4096 Dec  2 10:28 Data
So please give 755 to the /opt and re-create the Community Server container with the default access rights.
Postby penzoiders » Wed Dec 02, 2015 8:02 pm
Hi Dean
Dean wrote:It can be enough to be 755, but let me ask you, what was the purpose of performing that commands:
This was because I had an error while creating new documents (and aswell I had no sample docs when running the container the first time
by giving 755 to the /opt folder I get this
drwxr-xr-x  7 onlyoffice onlyoffice 4096 Dec  2 18:57 Services
drwxr-xr-x   7 root       root       4096 Dec  2 18:28 Data
so it is different than yours (your data folder there shows 777.. so it's really supposed to be so in production?
in this mode on the start of the container there where no sample docs on the docuents tab and the sphinx-settings test gave negative result.
I've found a thing by the way.
on the ubuntu host I removed completely the /opt/onlyoffice folder then created again and chowned with the same UID and GID that is in the container for the onlyoffice user and group:
mkdir /opt/onlyoffice
chown -R 103:106 /opt/onlyoffice
then started the container again and everything worked fine without chmodding -R 777 (that's actually something that makes me shivering every time I hear) and left the default 755
on the first run everything worked fine, in setting - sphinx-setting the full text search deamon was showing as running when I pressed "test", but the search tool was not actually giving any result even in searching the title of a test document.
then after a while (eg: creating a document or saving some portal customization settings) it stopped working (the sphinx-test was showing negative results again) tried to restart the container but no luck.
re-tried everything with 777 permissions but same results.
to double check I stopped and removed the container and re-run but nothing changed.
is there anything I can look at into the logs or by attaching to the container?
thanks again for support
NOTE: test done with firewall off on the host (ufw disable)
penzoiders
Postby penzoiders » Wed Dec 02, 2015 9:47 pm
I've tested the container itself. without the external data directory.
and the full text search is not working either.
docker run -i -t -d -p 80:80 --name onlyoffice-community-server --restart=always --link onlyoffice-document-server:document_server   onlyoffice/communityserver
or better.. it works in the first minutes when the container is started then the test stops and the search tool does not find anything.
by restarting the container or the whole host (eg: for a kernel update, a simulation I often do while testing a software), you end up with the full text search not working.
which are the log files to inspect ? anyone else can reproduce this behavior?
anyway after analyzing the default container permissions the best way to set owner and group for the external folder seem to be
in this way the permissions when linking the external folder to the container are completely the same that the default data directories in the container.
am I wrong?
penzoiders
Postby Dean » Thu Dec 03, 2015 1:15 pm
OK, let's start from the very beginning.
1) Stop onlyofficeIndex. Stop processes: searchd, indexer.
2) Clean the folder /var/www/onlyoffice/Data/Index
3) Clear table in the db: webstudio_index
4) Start onlyofficeIndex
In fact, it shall re-launch the Indexation service. Contact us and inform of the results, please.
Postby penzoiders » Mon Dec 14, 2015 4:57 pm
Sorry for replying this late:
I've restored to a clean state the community-server container and data folders
docker stop onlyoffice-community-server
docker rm onlyoffice-community-server
rm -rf /opt/onlyoffice
mkdir -p /opt/onlyoffice/Data/certs
cp /opt/onlyoffice_BAK/Data/certs/* /opt/onlyoffice/Data/certs
chmod -R 755 /opt/onlyoffice
chmod 600 /opt/onlyoffice/Data/certs/onlyoffice.key
chmod 600 /opt/onlyoffice/Data/certs/dhparam.pem
started a new one
stated that the sphinx test won't work
attached to the container and did what Dean suggested:
service onlyofficeIndex stop
rm -rf /var/www/onlyoffice/Data/Index/*
mysql -u root
mysql> use onlyoffice;
mysql> Truncate table webstudio_index;
mysql> quit
service onlyofficeIndex start
then stated again that shpinx test gives "Full text search service is not running"
checked the folder and the table Dean has suggested:
folder is populated:
root@1d42e2c0aa6a:/# ls -l /var/www/onlyoffice/Data/Index/
total 0
drwxr-xr-x  8 onlyoffice onlyoffice  79 Dec 14 16:25 community
drwxr-xr-x 10 onlyoffice onlyoffice 103 Dec 14 16:25 crm
drwxr-xr-x  4 onlyoffice onlyoffice  30 Dec 14 16:25 files
drwxr-xr-x  4 onlyoffice onlyoffice  32 Dec 14 16:25 mail
drwxr-xr-x  7 onlyoffice onlyoffice  80 Dec 14 16:25 projects
table is empty:
Database changed
mysql> select * from webstudio_index;
Empty set (0.00 sec)
should I update something inside of the docker container somehow after running it first time?
Dean, do you want an access to it so you can sneak-a-peek.. maybe can be useful for you guys to test this behaviour. I can give you a test VM with root access of course.
thanks for support.
cheers
penzoiders
Postby Dean » Tue Dec 15, 2015 5:37 am
We've just detected the bug with a new Sphinx version 2.10 and shall fix it in the future release. Sorry for the inconvenience.
Next
Users browsing this forum: Baidu [Spider] and 1 guest
