Option to Edit/Create documents
Postby Question » Mon Aug 10, 2015 8:31 am
i'd installed using docker methods, on Arch Linux, everything up to date... but cant edit/create documents, just share, why that happens?
Original message was posted on http://cloud.onlyoffice.org/viewtopic.php?f=31&t=7585
Question
Re: Option to Edit/Create documents
Postby Dean » Mon Aug 10, 2015 8:33 am
Please specify the products installed, the installation method and the documents format.
