OnlyOffice and NextCloud running on one host
Postby kaondr » Sun Sep 23, 2018 7:07 pm
I'd like to ask for help configuring to run OnlyOffice Document server as docker image and NextCloud (not Docker) using one physical server.
Currently I'm running NextCloud deployed directly on my server and CollaboraOnline Development Edition (CODE) as docker image. Anyway, I'm not happy with current setup and I'd like to replace CODE with OnlyOffice Document server.
Web server is run by Ubuntu 18.04, nginx 1.14.0.
My current nginx config file:
server {
    listen 80;
    server_name cloud.myweb.com;
    return 301 https://cloud.myweb.com$request_uri;
server {
    listen 443 ssl http2; # managed by Certbot
    ssl_certificate /etc/letsencrypt/live/cloud.myweb.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/cloud.myweb.com/privkey.pem; # managed by Certbot
    include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
    ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
    # Add headers to serve security related headers
    add_header Strict-Transport-Security "max-age=31536000" always;
    add_header X-Content-Type-Options nosniff;
    add_header X-XSS-Protection "1; mode=block";
    add_header X-Robots-Tag none;
    add_header X-Download-Options noopen;
    add_header X-Permitted-Cross-Domain-Policies none;
    # Path to the root of your installation
    root /usr/share/nginx/nextcloud/;
    location = /robots.txt {
        allow all;
        log_not_found off;
        access_log off;
    location = /.well-known/carddav {
        return 301 $scheme://$host/remote.php/dav;
    location = /.well-known/caldav {
    location ~ /.well-known/acme-challenge {
      allow all;
    # set max upload size
    client_max_body_size 512M;
    fastcgi_buffers 64 4K;
   ### Start Collabora Online ###
   location ^~ /loleaflet {
     proxy_pass https://localhost:9980;
     proxy_set_header Host $http_host;
   location ^~ /hosting/discovery {
   location ^~ /lool {
     proxy_set_header Connection "upgrade";
   ### End Collabora Online ###
    # Disable gzip to avoid the removal of the ETag header
    gzip off;
    error_page 403 /core/templates/403.php;
    error_page 404 /core/templates/404.php;
    location / {
       rewrite ^ /index.php$uri;
    location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)/ {
       deny all;
    location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console) {
       deny all;
    location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
       include fastcgi_params;
       fastcgi_split_path_info ^(.+\.php)(/.*)$;
       fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
       fastcgi_param PATH_INFO $fastcgi_path_info;
       #Avoid sending the security headers twice
       fastcgi_param modHeadersAvailable true;
       fastcgi_param front_controller_active true;
       fastcgi_pass unix:/run/php/php7.2-fpm.sock;
       fastcgi_intercept_errors on;
       fastcgi_request_buffering off;
    location ~ ^/(?:updater|ocs-provider)(?:$|/) {
       try_files $uri/ =404;
       index index.php;
    # Adding the cache control header for js and css files
    # Make sure it is BELOW the PHP block
    location ~* \.(?:css|js)$ {
        try_files $uri /index.php$uri$is_args$args;
        add_header Cache-Control "public, max-age=7200";
        # Add headers to serve security related headers (It is intended to
        # have those duplicated to the ones above)
        # Optional: Don't log access to assets
        access_log off;
   location ~* \.(?:svg|gif|png|html|ttf|woff|ico|jpg|jpeg)$ {
        # Optional: Don't log access to other assets
        access_log off;
I know I need to change this part, but I don't know how exactly.
location ^~ /lool {
I haven't created any docker network, currently I'm executing CODE docker image like this:
docker run -t -d -p 127.0.0.1:9980:9980 -e "domain=cloud\\.myweb\\.com" -e "username=someusername" -e "password=justsomething" --restart always --cap-add MKNOD collabora/code
Having open ports 80 and 443 on my router.
So I guess that command for OnlyOffice Document server will be:
docker run -t -d -p 127.0.0.1:49443:443 -e "domain=cloud\\.myweb\\.com" -e JWT_ENABLED='true' -e JWT_SECRET='justsomething' --restart=always onlyoffice/documentserver
I am beginner to nginx and docker, so if you see some horrible flaw in my config I welcome any feedback.
Thanks for any help and suggestions.
Regards,
Ondra
kaondr
Re: OnlyOffice and NextCloud running on one host
Postby Carl » Wed Oct 10, 2018 1:22 pm
Hello Ondra,
The easier way to have ONLYOFFICE Document Server and Nextcloud on one machine would be using the Docker Compose. You can find the instruction here.
Users browsing this forum: Baidu [Spider] and 1 guest
