Spreadsheet column sorting makes browser tab freeze
Postby rudais » Thu Aug 02, 2018 10:19 am
There seems to be a problem with filtering in Spreadsheet editor. When a simple filter is applied to the column then tab seems to go in indefinite freeze.
Problem to occur on all borowsers, tried: Chrome, FF, Edge
Server side:
DS 9.6.3.663 However the problem was there before also 5.1.2.xx also had this issue
CS 5.1.5.59
rudais
Re: Spreadsheet column sorting makes browser tab freeze
Postby Maxim » Fri Aug 03, 2018 10:36 am
Hello rudais!
I have reproduced this issue successfully, thank you for your information! We will fix it in version 5.2, current version is 5.1.5.
