Data Container with Traefik
Postby temparus » Tue Jul 17, 2018 9:22 pm
As the example docker-compose file in the repository on GitHub [1] suggests to use an additional data container. We named it «onlyoffice-documentserver-data».
On our Docker Swarm Cluster, we use Traefik as reverse proxy. Both services (onlyoffice-documentserver and onlyoffice-documentserver-data) are in the same swarm overlay network.
The incoming requests are forwarded to the onlyoffice-documentserver service, but returns the nginx error page «502 Bad Gateway», e.g. when requesting «https://<onlyoffice-domain>/welcome/».
In the log of the onlyoffice-documentserver service, we find the following entry:
2018/07/17 22:37:23 [error] 1673#1673: *4 connect() failed (111: Connection refused) while connecting to upstream, client: 10.0.0.10, server: , request: "GET /welcome/ HTTP/1.1", upstream: "http://127.0.0.1:8000/welcome/", host: "<onlyoffice-domain>"
In the log of the onlyoffice-documentserver-data service, we find the follwing entry:
If we do not split the onlyoffice-documentserver into two services, it works as expected. We want it to be scalable (multiple instances in parallel), so I think that the data container is mandatory.
Any ideas what the cause could be for this issue?
[1] https://github.com/ONLYOFFICE/Docker-DocumentServer
temparus
Re: Data Container with Traefik
Postby Maxim » Fri Jul 20, 2018 7:06 am
Hello temparus!
1. I do not understand why it needs 2 doc servers for you and i do not see any reason to set up 2 document server containers. Only if you do not want to pay for the commercial license )))).
2. It looks like that you try to create a cluster system, which is managed under commercial license.
Have no idea...
Postby DaftHonk » Mon Sep 17, 2018 6:11 pm
Maxim wrote:2. It looks like that you try to create a cluster system, which is managed under commercial license.
I am attempting to run ONLYOFFICE Community Server on my home server using Portainer to manage my single-node swarm as it does not have built in compose functionality. Where exactly is it stated that the ONLYOFFICE stack cannot be run in swarm mode? Even though I only have a single container running for each, all containers but mySQL fail repeatedly when running in swarm mode.
DaftHonk
