Unprivileged Docker image for use in K8s and OpenShift
Postby cnt » Fri Jul 06, 2018 11:35 am
I have try to deploy the documentserver docker image in OpenShift and have big problems as 'run-document-server.sh' expects to be run as root. For example modifing the configs during runtime in /etc/onlyoffice and starting services like supervisord+nginx require root. I tried to workaround it some time but always found myself in deadends. Is there an unpriviledged docker image I'm not aware of or in development? I need to build one just containing nginx + documentserver which uses external postgres,redis and rabbitmq.
Kind regards,
Christian
cnt
Re: Unprivileged Docker image for use in K8s and OpenShift
Postby dsi-lille » Mon Jul 09, 2018 6:22 am
i have the same request :)
We begin to deploy OpenShift, and it require that all docker images don't run as root...
Thanks,
Yoann
dsi-lille
