Backup of Documentserver on Docker.
Postby falkowich » Tue May 15, 2018 10:17 am
Is there a "right" way of backing up the Community - Documentserver on docker containers?
I'm thinking of scripting -> https://helpcenter.onlyoffice.com/de/se ... aspx#Step1
From what I can understand all the "documents" and data is in /app/onlyoffice?
user@server:/app/onlyoffice$ ls -alh
total 32K
drwxr-xr-x 8 root root 4,0K apr  6 16:08 .
drwxr-xr-x 3 root root 4,0K apr  6 16:08 ..
drwxr-xr-x 4 root root 4,0K apr  6 16:08 CommunityServer
drwxr-xr-x 4 root root 4,0K apr  6 16:08 ControlPanel
drwxr-xr-x 6 root root 4,0K apr  6 16:08 DocumentServer
drwxr-xr-x 4 root root 4,0K apr  6 16:08 MailServer
drwxr-xr-x 6 root root 4,0K apr  6 16:08 mysql
drwxr-xr-x 2 root root 4,0K apr  6 16:08 setup
So if I backup these, everything is honky dory? :)
And the usual snapshot backups of the whole vm...
Regards Falk
falkowich
Re: Backup of Documentserver on Docker.
Postby Maxim » Tue May 15, 2018 10:56 am
Hello falkowich!
To backup you need to make a reserve copy /app/onlyoffice/, but it will need to install the same versions of Community Server container and Document Server container.
Or you can make a copy of next folder /app/onlyoffice/CommunityServer/data/ and create MySQL dumpfile of onlyoffice database.
