Custom domain name / wrong Domain in outgoing mails
Postby e5sego » Tue May 08, 2018 10:11 pm
Hi all,
after fighting for a while to get the installation of CommunityServer (plus DocumentServer) to run on docker, using apache as reverse proxy to connect between the internal port 1443 and the public port 443, I noticed all outgoing mail will use the internal IP adress (but without the port) as hostname in links. So those liks are not valid from outside.
E.g. the change passwort link look like https://172.18.0.3/confirm.aspx?type=Pa ... nge&key=...
Activating the "Custom domain name" like in https://helpcenter.onlyoffice.com/getti ... ation.aspx does not change this behavior.
How can I setup the domain name used to generate links to the portal?
Best,
Sebastian
e5sego
Re: Custom domain name / wrong Domain in outgoing mails
Postby Maxim » Fri May 11, 2018 9:26 am
Hello Sebastian!
What is version of Community Server?
