Error: self signed certificate in certificate chain
Postby qloc » Fri Apr 13, 2018 12:33 pm
We got nextcloud running internally using an ssl certificate signed by our internal CA.
We now installed the documentserver via docker and and tried connecting the nextcloud to it, however this does not work.
The logs of the documentserver converter show this error when trying to save the onlyoffice settings in nextcloud:
[2018-04-13 12:22:39.257] [ERROR] nodeJS - error downloadFile:url=https://nextcloud/index.php/apps/onlyoffice/empty?doc=UDBXWHpsV0VJbWVIdzl6bEJWbFovRXVPUncveWE5S3U3djZBV29XMlJtRT0/eyJhY3Rpb24iOiJlbXB0eSJ9;attempt=3;code:SELF_SIGNED_CERT_IN_CHAIN;connect:undefined;(id=conv_check_397808624_docx)
    at Error (native)
    at TLSSocket.<anonymous> (_tls_wrap.js:1092:38)
    at emitNone (events.js:86:13)
    at TLSSocket.emit (events.js:185:7)
    at TLSSocket._finishInit (_tls_wrap.js:609:8)
    at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:439:38
qloc
Re: Error: self signed certificate in certificate chain
Postby Maxim » Thu Apr 19, 2018 1:35 pm
Try to place CA certs in Docker container for the system, i do not know will it help.
