Document Server Location on Community Server instance?
Postby nickt » Thu Mar 22, 2018 1:22 am
I was able to successfully install the Community Server and Document server via Docker and I have the Community server running with SSL. I can see with "docker ps -a" that this is what I have running:
CONTAINER ID        IMAGE                                  COMMAND                  CREATED             STATUS              PORTS        NAMES
bf5da8221700        onlyoffice/communityserver:9.6.0.593   "/usr/bin/dumb-init …"   26 hours ago        Up 3 hours          0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp, 3306/tcp, 5280/tcp, 9865-9866/tcp, 9871/tcp, 9882/tcp, 0.0.0.0:5222->5222/tcp, 9888/tcp   onlyoffice-community-server
f2781dbaa0e0        onlyoffice/documentserver:5.0.7.38     "/bin/sh -c 'bash -C…"   26 hours ago        Up 3 hours          80/tcp, 443/tcp        onlyoffice-document-server
39147bf08a28        mysql:5.7.20                           "docker-entrypoint.s…"   26 hours ago        Up 3 hours          3306/tcp        onlyoffice-mysql-server
But I can't seem to access the straight document server (the page that just says "Document Server is Running". How can I access the Document Server address, separately from the Community Server? Looking at the ports, I'm a little confused. Are they both running on 80/443?
The reason I'm asking is because I'm not sure what to put in NextCloud in order to connect that server to this one.
Thanks!
nickt
Re: Document Server Location on Community Server instance?
Postby nickt » Thu Mar 22, 2018 9:10 pm
I discovered the solution here. If you're running Community Server, you have to use this address for the Document Server: https://yourdom.com/ds-vpath/
nickt
Postby Maxim » Tue Apr 03, 2018 10:41 am
Hello nickt!
You're right! You need "ds-vpath" parameter.
