Spreadsheet: Copy/Paste Accounting Formatted Cell Does Not D
Postby Merc » Wed Feb 28, 2018 11:42 pm
Spreadsheet: Copy/Paste Accounting Formatted Cell Does Not Display
Enter a simple formula in a spreadsheet cell. Display the result.
Select the cell and format it as Accounting (using format menu in toolbar). Display the newly formatted result.
Copy (using appropriate keyboard command) the Accounting formatted cell and paste it (using keyboard command) to a new cell.
The formula will be pasted in the target cell as expected (check in formula bar) but the result will not display.
Close the document, wait for the editing pencil to update (go gray), re-open.
The result of the pasted cell will appear.
Verified with Firefox 58.0.2/Mac, Chromium 64.0.3282.186/Mac, Firefox 58.0.2/Linux
OnlyOffice CE, Ubuntu 16.04.3
Docker version 17.05.0-ce, build 89658be
onlyoffice/documentserver 5.0.7.38
onlyoffice/communityserver 9.5.4.553
Merc
Re: Spreadsheet: Copy/Paste Accounting Formatted Cell Does N
Postby Maxim » Thu Mar 01, 2018 7:37 am
Hello Merc!
Please attach screenshot(s)
Postby Merc » Thu Mar 01, 2018 5:54 pm
The attached file shows a sequence of copy and paste of an Accounting formatted cell (formula) using the contextual menu.
The pasted cell has the correct formula embedded but the result is invisible. Close and open the sheet and the results appear.
oods-copy-paste-error.zip
Copy-Paste of Accounting formatted cell is Invisible
(59 KiB) Downloaded 51 times
Merc
Postby Maxim » Wed Mar 07, 2018 10:29 am
Hello Merc!
There is a hard-to-catch bug when you try to paste (ctrl+v) something and you will not get the result as it supposed to be, but it happens when the browser's cache is clean. Usually after several tries to paste the bug doesn't repeat.
