Document server : "The document could not be saved"
Postby nicnac » Tue Feb 20, 2018 1:15 pm
Hello everyone,
I just install a Document server instance of onlyoffice on a Ovh VPS Docker host.
I'd like to integrate this instance with an HumHub' social network thought the adequate module, but when I want to create a new document, the document server inform me that "The document could not be saved, check connection setitings"
Does any one kwnow about this issue ?
thx a lot !
nicnac
Re: Document server : "The document could not be saved"
Postby Maxim » Thu Feb 22, 2018 8:44 am
Hello nicnac!
If you want to integrate the Document Server in your environment you should visit our API.
About saving file you should see this tutorial.
Postby nicnac » Tue Feb 27, 2018 3:34 pm
Hi Maxim!
Thanks for your answer, I'll try to follow these instructions to fix my problem.
In fact, I do not need to code an API, I already use one develop for HumHub (https://github.com/humhub/humhub-modules-onlydocuments)
Do you think my solution is in docker configuration?
2018-02-27 (5).png (98.24 KiB) Viewed 618 times
nicnac
Postby Maxim » Wed Feb 28, 2018 7:08 am
Hello nicnac!
We are on Github
in that case how you are going to integrate this instance with an HumHub' social network? I do not know, we do not have any connector.
Maybe they have connector like we have (see here) or there should be any tutorial how to make it up.
Users browsing this forum: DaftHonk and 3 guests
