Where is the Data?
Where is the Data?
Postby antons » Mon Feb 05, 2018 9:23 am
There is no any data in /var/www/onlyoffice/DocumentServerData and other directories. Docker installation on Ubuntu 16 server.
How to find data location for backup purposes? Community edition.
Thank You in advance!
I follow Linux docker installation instructions. No these folders are created in installation process to store data outside docker. After investigation I found data in /app/onlyoffice folder. There is also log files.
It can be OK?
antons
Re: Where is the Data?
Postby Maxim » Wed Feb 07, 2018 12:49 pm
Hello antons!
for backup purposes - you need to copy
/app/onlyoffice/CommunityServer/data/
it's on the host machine, you shouldn't get inside of the container.
Postby antons » Wed Feb 07, 2018 3:57 pm
OK Clear.
Thank You!
antons
Postby Maxim » Mon Feb 12, 2018 11:06 am
Hello antons!
You are welcome!
Users browsing this forum: No registered users and 5 guests
