Comm.server on alternative port makes docsrv not working
Postby eMarcus » Thu Jan 18, 2018 3:41 pm
I have set up community server and document server using the docker images provided on docker-hub. I have set up the two containers as described in the Readme. So only the ports of the community server are exposed outside the host. As long as I use the standard ports (443->443 and 80->80) on both servers, everything works fine. When I move the exposed port of my community server to something else (8443->443), the portal is still working fine under the new URL, however, I cannot edit any documents.
Can anyone help me on how I must either configure the document-server docker container or the doc-server URLs in the community server setup to work when the community server is accessed via a non standard port?
Thanks in advance,
Marcus.
eMarcus
Re: Comm.server on alternative port makes docsrv not working
Postby Maxim » Mon Jan 22, 2018 8:06 am
Hello eMarcus!
Please attach screenshot of your Document Service Location.
