[Docker/Ubuntu] Compilling and buildingDocumentServer failed
Postby Miodrag » Wed Dec 13, 2017 10:41 am
Hello guys,
I am trying to compile and build Document server in ubuntu:14:04 docker image.
I've been following instructions from here: https://helpcenter.onlyoffice.com/serve ... -code.aspx
The problem occured in downloading and building 3rd party modules, and I got following error:
[P10782 10:28:03.384 remote.go:105 W] cipd: connectivity error (Get https://chrome-infra-packages.appspot.c ... ed4f5cb4ad: dial tcp: lookup chrome-infra-packages.appspot.com on 10.241.75.254:53: read udp 172.17.0.2:42295->10.241.75.254:53: i/o timeout)
Error: resolving package: failed to resolve package version (line 11): request to the backend failed after multiple attempts.
If someone has some suggestions, I would be very greateful.
Thank you in advance!
Miodrag
