Problem with access from the Internet
Postby domcom » Thu Nov 09, 2017 3:12 pm
Hello Friends.
I'm come across a problem that i can't solve and i don't know why and i hope you can help.
My Problem is, that when a User connects over the Internet to my OnlyOffice, he can't upload or edit any files. I get the errormessage:
ONLYOFFICE™ is not available. Please contact us at support@onlyoffice.com
From the LAN there is no Problem, only from the Internet...
I tryed some different things out, but nothing worked.
I don't know if i done something wrong in the Konfigurations(Documentservice) or what the Problem is.
My Documentservice Settings are:
http://mydomain.com/coauthoring/CommandService.ashx
http://mydomain.com/FileUploader.ashx
http://mydomain.com/ConvertService.ashx
http://mydomain.com
My OnlyOffice is installed on an Hyper-V Cluster on a VM that is running an Ubuntu 16.04 LTS.
The installation is done with Docker(installation Guid from OO without the Mailserver), and the DMZ is done with a Netscaler(that should be correct configurated).
Regards
DomCom
domcom
Re: Problem with access from the Internet
Postby Maxim » Fri Nov 10, 2017 2:10 pm
Please show your settings of Document Service Location, there is no first one.
Postby domcom » Tue Nov 14, 2017 2:33 pm
Hi maxim.
The Document Service Location is
/web-apps/apps/api/documents/api.js
When i add my DNS to the string nothing changes, i still get the error 302 found.
domcom
Postby Maxim » Mon Nov 20, 2017 11:39 am
Hello domcom!
Please change next
1. "/web-apps/apps/api/documents/api.js" to "/ds-vpath/web-apps/apps/api/documents/api.js"
2.
"http://mydomain.com/coauthoring/CommandService.ashx" - "http://onlyoffice-document-server/coauthoring/CommandService.ashx
"http://mydomain.com/FileUploader.ashx" - "http://onlyoffice-document-server/FileUploader.ashx"
"http://mydomain.com/ConvertService.ashx" - "http://onlyoffice-document-server/ConvertService.ashx"
3. The last one should be your domain name
Example
Document Service Location.png (47.69 KiB) Viewed 985 times
