XMPP - WebHook ?
XMPP - WebHook ?
Postby Issa » Wed Nov 08, 2017 9:17 am
Hello evrybody,
with onlyOffice u have an XMPP serveur it's really cool, i m using it whti Jitsi (don't like jitsi interface, but works)
but now i need a webHook syteme.
In xmpp i create some room chat.
i want create a bot to send message via command line, and i want to know how to do that.
i see this function with Discord :
The Webhooks feature built into Discord is a simple way to receive automated messages and updates directly in a text lounge on your server. See this as one of those pneumatic tubes that are sometimes used to send money inside a bank and that you can watch disappear, but instead of never seeing your money again, you will actually see shared messages in Discord from another platform.
what do u think ?
Issa
Re: XMPP - WebHook ?
Postby Issa » Wed Nov 08, 2017 9:58 am
i found this :
https://xmpp.org/extensions/xep-0070.html
https://make.wordpress.org/core/2010/07 ... over-http/
i mlooking on onlyOffice API but i found nothing ?
https://api.onlyoffice.com/portals/section/settings
but now i need to make it works with onlyOffice chat module who using XMPP
what do u think please ?
Issa
