[SOLVED] - Unknow error : when editing or create document
Postby Issa » Fri Oct 13, 2017 7:13 am
Hello there,
i m on a frech install using docker on ubuntu 16.04.
using this how to --> https://www.linuxbabe.com/linux-server/ ... untu-16-04
my probleme is when i try to create a document i have this error :
can u please helpe me to found how debug this probleme
thanks
Issa
Re: Unknow error : when editing or create document
Postby Maxim » Fri Oct 13, 2017 7:27 am
Please use our instruction to install Onlyoffice for Docker using provided script - Community Edition or Enterprise Edition.
Postby Issa » Fri Oct 13, 2017 7:28 am
about my installation :
this my container :
onlyOffice@srv-linux-01:~$ sudo docker ps
[sudo] password for onlyOffice:
CONTAINER ID        IMAGE                        COMMAND                  CREATED             STATUS              PORTS        NAMES
797d3ddb8641        onlyoffice/communityserver   "/usr/bin/dumb-ini..."   25 hours ago        Up 18 hours         443/tcp, 3306/tcp, 5280/tcp, 9865-9866/tcp, 9871/tcp, 9882/tcp, 9888/tcp, 0.0.0.0:5222->5222/tcp, 0.0.0.0:8080->80/tcp   onlyoffice-community-server
eb4fcf3c20ea        onlyoffice/mailserver        "/bin/sh -c 'expor..."   2 days ago          Up 18 hours         0.0.0.0:25->25/tcp, 0.0.0.0:143->143/tcp, 3306/tcp, 0.0.0.0:587->587/tcp, 8081/tcp                                       onlyoffice-mail-server
057848c2e769        onlyoffice/documentserver    "/bin/sh -c 'bash ..."   2 days ago          Up 18 hours         80/tcp, 443/tcp        onlyoffice-document-server
this is my nginx :
server {
        listen 80;
        server_name oo.myDomaine.com;
        return 301 https://$server_name$request_uri;
server {
        listen 443 ssl http2;
       ssl                  on;
       ssl_certificate      /etc/ssl/oo.myDomaine.com/oo.myDomaine.com.crt;
       ssl_certificate_key  /etc/ssl/oo.myDomaine.com/oo.myDomainee.com.key;
        ssl_session_timeout 1d;
        ssl_session_cache shared:SSL:10m;
        ssl_session_tickets off;
        ssl_protocols TLSv1.1 TLSv1.2;
        error_log /var/log/nginx/onlyoffice.error;
        access_log /var/log/nginx/onlyoffice.access;
        location / {
                proxy_pass http://127.0.0.1:8080;
Issa
Postby Issa » Mon Oct 16, 2017 8:32 am
Hello my problem is solved with this step :
so i do this simple task :
1> Install frech ubuntu server 16.04 LTS
2> Install OnlyOffice with script :
- wget http://download.onlyoffice.com/install/ ... install.sh
- bash opensource-install.sh -md "yourdomain.com"
3> Create my own ssl certificate :
- domaine=oo.mydmoine.com
- cd /etc/ssl
- mkdir $domaine
- cd $domaine
- openssl genrsa -out $domaine.key 2048
- openssl req -new -key $domaine.key -out $domaine.csr
- openssl x509 -req -days 365 -in $domaine.csr -signkey $domaine.key -out $domaine.crt
4> Copy certificat files on docker onlyOffice :
- cp /etc/ssl/$domaine.key ./app/onlyoffice/CommunityServer/data/certs/onlyoffice.key
- cp /etc/ssl/$domaine.crt /app/onlyoffice/CommunityServer/data/certs/onlyoffice.crt
5> restart docker community
- found docker id with
- docker ps
- restart the cdocker community :
- docker restart b510353c2b25
6> go to web access https://yourdomain.com
and works
thanks !!!!
Issa
Re: [SOLVED] - Unknow error : when editing or create documen
Postby Maxim » Tue Oct 17, 2017 7:45 am
Hello Issa!
:D
