have to setup docker install again after backup
Postby zwnk » Fri Sep 08, 2017 12:09 am
Hi there,
i setup the ce with docker on windows 10 pro and it is running well. But now i have the problem that i have to setup up the ce again via webinterface after i stopped the servers to update docker.
The same happend to me 2 weeks ago after stopping the container to backup the data.
Can someone help me to prevent that issue?
Cheers
zwnk
Re: have to setup docker install again after backup
Postby Maxim » Fri Sep 08, 2017 6:42 am
Hello zwnk!
Please specify did you installed on VM machine?
You can start docker containers again
docker ps
it shows containers
docker start [OPTIONS] CONTAINER [CONTAINER...]
Postby zwnk » Fri Sep 08, 2017 11:38 am
thank you but i'm well aware of that.
i use windows 10 pro with docker ce Version 17.06.2-ce-win27 (13194)
the docker container were stopped and started. I did not create a new container nor reloaded the image.
Y:\>docker ps -a
CONTAINER ID        IMAGE                        COMMAND                  CREATED             STATUS                        PORTS               NAMES
cc92a3331bde        onlyoffice/communityserver   "/usr/bin/dumb-ini..."   2 weeks ago         Exited (143) 16 seconds ago                       onlyoffice-community-server
9546cb834bad        onlyoffice/mailserver        "/bin/sh -c 'expor..."   2 weeks ago         Exited (137) 6 seconds ago                        onlyoffice-mail-server
aa549d7dc3e2        onlyoffice/documentserver    "/bin/sh -c 'bash ..."   2 weeks ago         Exited (137) 6 seconds ago                        onlyoffice-document-server
as you can see. it is a container created 2 weeks ago.
zwnk
Postby zwnk » Fri Sep 08, 2017 11:43 am
the docker commands i used to setup the container:
docker network create --driver bridge onlyoffice
docker run --net onlyoffice -i -t -d --restart=always --name onlyoffice-document-server ^
   -v f:/ONLYOFFICE/DocumentServer/data:/var/www/onlyoffice/Data ^
   -v f:/ONLYOFFICE/DocumentServer/logs:/var/log/onlyoffice ^
docker run --net onlyoffice --privileged -i -t -d --restart=always --name onlyoffice-mail-server ^
   -p 25:25 -p 143:143 -p 587:587 ^
   -v f:/ONLYOFFICE/MailServer/data:/var/vmail ^
   -v f:/ONLYOFFICE/MailServer/data/certs:/etc/pki/tls/mailserver ^
   -v f:/ONLYOFFICE/MailServer/logs:/var/log ^
   -v f:/ONLYOFFICE/MailServer/mysql:/var/lib/mysql ^
   -h mail.dmcl.digimapas.cl ^
docker run --net onlyoffice -i -t -d --restart=always --name onlyoffice-community-server ^
   -p 80:80 -p 5222:5222 -p 443:443 ^
   -v f:/ONLYOFFICE/CommunityServer/data:/var/www/onlyoffice/Data ^
   -v f:/ONLYOFFICE/CommunityServer/mysql:/var/lib/mysql ^
   -v f:/ONLYOFFICE/CommunityServer/logs:/var/log/onlyoffice ^
   -v f:/ONLYOFFICE/DocumentServer/data:/var/www/onlyoffice/DocumentServerData ^
   -e DOCUMENT_SERVER_PORT_80_TCP_ADDR=onlyoffice-document-server ^
the batch i use to backup the container data:
REM stop docker container
docker stop onlyoffice-document-server onlyoffice-mail-server onlyoffice-community-server
REM copy data folder
xcopy /E /Y D:\onlyo y:\backup_onlyoffice
REM start docker container
docker start onlyoffice-document-server onlyoffice-mail-server onlyoffice-community-server
zwnk
Postby Maxim » Tue Sep 12, 2017 6:43 am
Hello zwnk!
Do you mean that the Onlyoffice wizard restarts after stopping container?
Maybe it would be better to install Community Edition using script where all needed parametrs included and work correctly.
Postby zwnk » Tue Sep 12, 2017 11:58 am
exactly, the webinterface starts the installation wizard again.
zwnk
Postby Maxim » Mon Sep 18, 2017 6:19 am
Hello zwnk!
Please show a screenshot of docker containers you have.
