Docker CE Server - How to Update?
Postby Merc » Thu Aug 10, 2017 7:42 pm
What is the correct procedure for updating an OnlyOffice CE Docker server once it's deployed? The server runs on Ubuntu 16.04.3 LTS and was installed using the install script (wget http://download.onlyoffice.com/install/ ... install.sh) over a year ago. No mail server is employed.
Can something like this command for component upgrade work?
bash enterprise-install.sh -md "yourdomain.com" -u true
(Reference: https://helpcenter.onlyoffice.com/serve ... eters.aspx)
Thank you.
Merc
Re: Docker CE Server - How to Update?
Postby Maxim » Fri Aug 11, 2017 8:01 am
Hello Merc!
Using parametr "-u true" you will update existing containers only.
If you want to use Mail Server you will need to reinstall Onlyoffice.
Before make backup please, i hope you have mapped folder app/onlyoffice.
After reinstallation everything should work correctly.
