Connect Xwiki to OnlyOffice
Postby dortiz04 » Fri Aug 04, 2017 6:23 pm
Does anyone have documentation or insight to connect xwiki to the document server? We purchased the xwiki add in extension and now attempting to connect it to the inhouse built document server. The onlyoffice server is up since I am able to log into it. This is the message I receive when I attempt to open a document from xwiki using the doc server.
Error: Script error for "http://<servername>/web-apps/apps/api/documents/api.js" http://requirejs.org/docs/errors.html#scripterror
dortiz04
Re: Connect Xwiki to OnlyOffice
Postby Maxim » Thu Aug 10, 2017 7:12 am
Hello dortiz04!
It's hard to say what it is and why. Maybe you can provide more info. Maybe logs can help you.
