web.appsettings.config unable to edit
Postby mahathir » Thu Jun 29, 2017 7:59 am
I'm having problem to edit web.appsettings.config
I try to edit but cannot. Please help me. I'm using Version 8.9.2.27 onlyoffice community version docker.
Mahathir
mahathir
Re: web.appsettings.config unable to edit
Postby Maxim » Fri Jun 30, 2017 7:42 am
Hello mahathir!
You can edit this file if you cannot it means that you have no permissions. You must be root user to edit.
Postby mahathir » Mon Jul 03, 2017 3:48 am
Ok thanks
mahathir
Postby Maxim » Mon Jul 03, 2017 6:30 am
Hello mahathir!
You are always welcome!
