Installation Issue with Community Server and Document Server
Postby ic57369k » Sat Jun 24, 2017 4:34 am
Hi
I have Ubuntu 16.04 LTS running.
I have apache 2 webserver running with default root in /var/www/html/
I installed Community Server and Document Server on a local server in docker using following
sudo docker run -i -t -d -p 8080:80 --name onlyoffice-document-server onlyoffice/documentserver
sudo docker run -i -t -d -p 8081:80 \
--link onlyoffice-document-server:document_server \
onlyoffice/communityserver
I am unable to install on port 80. It returns an error saying that port is already in use.
Now, when I fire community server using http://127.0.0.1:8081, everything works perfect. I see the dashboard. It completes the registration process. I then go to the Documents link. It lands me to the documents page. However, when I click on any sample document, say the ONLYOFFICE Sample Presentation.pptx, it takes me to the link http://127.0.0.1:8081/products/files/do ... x?fileid=2 and returns an error 404 Not Found nginx/1.10.0 (Ubuntu). Now, my document editor is running on port 8080. But it is not firing up the correct link (as I make out).
First of all, I have following observations to make
1. I cant see the location where onlyoffice is installed.
2. I dont the document editor as demonstrated in the videos. I am missing some configuration (I know for sure, but am not able to comprehend).
3. On putting the link http://127.0.0.1:8080, my document server webpage opens up with the only statement saying "Document Server is Running".
4. Why am I not landing to the document editor page to edit documents.
Help is solicited please.
main screen of community server.jpg (110.67 KiB) Viewed 504 times
on clicking spreadsheet.jpg (75.72 KiB) Viewed 504 times
ic57369k
